Using old silicone lesson too late
  • newood2
    • 600
    • Brooklyn, NY.
    I pulled out a tube of GE Type 11 silicone sealant that was sitting on the shelf for quite some time to caulk the joints of some 4" flexible metal elbows for my dust collecting ductwork. It should have become tackless in 30 minute and fully cured in 24 hours. well, after 12 hours it's still sticky.
    I went on the Net for some info and found this.
    "http://www.factsfacts.com/MyHomeRepair/caulk.htm
    Note: If silicone does not cure it makes a godawful mess. Most manufacturers specify a shelf life of 1-year from date of manufacturer for silicone caulk in unopened tubes. I've not seen times for partially used tubes. Silicone will last longer than a year, but if it's old you must test it to see if it is going to cure. Silicone does not air dry, it has a curing agent. If a sample placed on a non-porous surface does not cure in 24 hours don't use it."
    Checked the date on the tube and it said 04/04.
    Looks like I messed up here. Now, how do get this off my cabinet(one elbow is screwed and sealed to the router cabinet). The 5 elbows themselves probable would be easier to replaced rather than try to clean that stuff off them. This is aggravating considering I did a lot of work riveting mounting brackets on these guys.
    Is there a chance this thing will ever cure?
    I hate silicone, is there another product I can use that will last as long and cleaned up easily?
    This is a baaaad day.
    Howie
  • Salty
    • 690
    • Akron, Ohio
    You could try putting some new stuff over the old. Maybe the curing agent will help cure to old stuff. If not, it may still creat a layer of cured over top of the old.
      I haven't found anything that will dissolve dried or semi-cured silicone. For whatever stage of "cure" you're in, I'll give you a short list to try. I don't know what you have to remove it from, so be careful with these solvents and try to get some ventilation. I would not apply fresh silicone over old.
      1. Denatured alcohol
      2. Isopropyl alcohol
      3. Acetone
      4. Lacquer thinner
      5. VM&P naptha
      6. Mineral spirits
      7. Turpentine
      8. Kerosene
      9. Tolueno/toluene
      If you find something that works that isn't on the list, let me know. Oh, BTW, NO open flames.
      • Whit
        • Apr 2003
        • 110
        • Denton, Tx, USA.
        • BT3000, BT3100
        When replacing old cured silicone( several years old and it has started to peel), I scrape the bulk of it off and then use a paper towel moistened with mineral spirits. Works for me. So, for the uncured stuff, I would try the same technique.
        Good luck
        Whit
        • wardprobst
          • 681
          • Wichita Falls, TX, USA.
          • Craftsman 22811
          Remove as much as you can mechanically(scraping/cutting). I think Xylene will clean up the rest. Use rubber gloves, plenty of ventilation, it's nasty stuff.
          DP
          www.wardprobst.com
            I would lt sit for a few days to let it cure to whatever degree it's going to cure. Then get after it with a box of the commercial razor blades you can get at the Orange Box. Wear gloves. Get what you can off and let the rest cure another day and then cover with new caulk.
            I am thinking that if you try to dissolve it it will just soften to some degree and be a mess to clean off as it will just spread like peanut butter. The harder it is, the easier it will be to get under it with a razor blade and more or less shave it off. As far as I know, there is no known solvent for silicone.
            Regards...
            • newood2
              • 600
              • Brooklyn, NY.
              I waited a week but it still didn't cure, so I through out the elbows and got new ones. I scraped off as much silicone as I could from around the cabinet holes and used the paint thinner to clean up the rest. It worked pretty good.
              Oh, the new tube of silicone was tack free in about 20mins.
              Thank you fellow WW
              Howie
