I am doing some veneer panels (to cover the ends and the like) for my kitchen cabinets. I'm using Ash veneer over a 1/4" plywood. So simple stuff really, no fancy patterns or shaped, just flat rectangles mostly.
Anyway, somewhere, I don't recall when or where, I read that you can use regular yellow glue painted on both pieces (substrate and veneer), when it's dry, you can move them around to get them lined up properly, then iron it on. The yellow glue apparently is heat activated. This sounds much easier than using a contact cement, that, once the 2 pieces touch, they're almost too bonded to make adjustments. I tried both ways tonight, and the yellow glue (I used Titebond II) and ironing works, but will it last? Unfortunately I wasn't smart enough to cut the veneer pieces a little larger than the panels, so I can't afford glueing mistakes.
How are you doing it?
All rational answers will be appreciated.
Thanks,
Johan
Thanks,
Johan
