Thom,
Lee suggested I direct this to you as he informed me that you have more experience working with phenolic than he does.
I'm making this mortising jig and it requires a custom base plate for my plunge router* (see attachment). I've got the phenolic plate and all (yeah right) I have to do is cut it and drill out the center hole. Before I totally screw up a $12.00 plate, I figured I best ask you if my thinking if right, at least in reference to doing this.
A. Can I cut the plate to size using an 80 tooth carbide Freud blade on the 3100?
B. To drill out the large center hole, I have Forstner bits that are large enough to do the center hole (I have a Dewalt and the hole is less than the one shown (Porter-Cable). I guess a slow speed (300 rpms) on the drill press is good?
C. Any special speed I should use drilling the smaller holes and routing the slots on the base.
D. Now the really hard question. Do I leave the paper backing on after I'm finished, or does it get peeled off?
Thanks in advance for the help from you and anyone else
Bruce
Bruce
