First Commissioned WW Project
  • bigsteel15
    • 1079
    • Edmonton, AB
    WOOHOO!!
    I'm almost embarrassed to tell what it is, but I got my first commission today.
    Not exactly fine WW but one of my bosses (3) came to me today and said he needed 4 outrigger pads made for our portable crane. He asked could I contact the guys we use for making crates, shipping supports, etc.
    Robin (boss): "I would get the guys in the shop to do it but we are short staffed already and I'll probably get crap for wasting valuable time"
    Brian: "What do they look like?"
    Robin: "Just 30-36" square x 4-6" thick wood blocks with a rope handle attached to each end"
    Brian: "I can make those"
    Robin: "Really?"
    Brian: "Sure, no problem, just pay for the materials and a little something for my time."
    Robin: "OK let us know how much"
    Brian then proceeds (after smacking himself upside the head) to go out after work and purchase said materials:
    (18) 2x6 x 12 ft
    (2) sheets 3/4" cheap plywood
    40 ft 3/4" OD poly rope
    Total: $210.00
    Started cutting up pieces (just under 32" long so as to fit 3 on a 96" sheet of plywood)
    2x6 pieces, 6 wide, cross next layer, screw together, cross next layer, screw together, sandwich this stack between layers of plywood and screw together...WAY too many screws.
    I think this will warrant rental of a framing nailer this weekend.
    I won't get to use a lot of tools: CMS, CS, Router.
    Sorry this is so long, but I do have questions:
    How much does Gorilla glue expand? I'm thinking of using it to fasten the rope in a 3/4" groove sandwiched between 2 layers of 2x6.
    Do you think it will hold, or will the glue melt the rope? the other option is to tie a knot in the rope and make a large receiving area for the knot at the end of the groove.
    Brian
    Welcome to the school of life
  • bigsteel15
    • 1079
    • Edmonton, AB
    So I asked Robin today if the Poly rope was OK. NOPE!!
    He asked me to use nylon. Apparently poly doesn't do well outside over the long term.
    Nylon is 2-1/2X the price, but oh well, not my money.
    So back to my question about Gorilla glue for holding the rope.
    Will it work, or destroy the nylon rope?
    Brian
    • RayintheUK
      • 1792
      I wouldn't rely on any type of glue in the circumstances you describe, Brian. Knotted ends will be much more secure.
      Ray.
      Did I offend you? Click here.
        BRRRRRRTTTT! Hey, thanks for playing, but if you can build a project without finding an excuse to buy a new tool, you're automatically disqualified, with a mandatory six week suspension.
        • bigsteel15
          • 1079
          • Edmonton, AB
          So thinks you
          Actually, see this post.
          http://www.bt3central.com/showthread.php?t=22502
          My existing CMS is a $100 POS and I've been looking for an excuse to upgrade.
          Either that or HD has a framing nailer on clearance that I'm going to look at right now. Now there's something I'd buy and maybe never use again.
          TAKE THAT Larry!!
          Brian
