Big rust - how to fix?
  • brooks
    • May 2006
    • 106
    I have a small compressor but it weighs nearly 70 pounds so I want to put it on a rolling platform. I found an old dolly for free (looks something like http://www.jasco.com.au/files/images...0Handtruck.jpg) but it's totally rusty on the platform part. I can't decide how to handle it. It's the right size and the right price - if I don't have to buy a sandblaster to fix it.
    Any ideas?
    Belt sander, with a 40, 60, or 80 grit belt. It's what I use on my big arn. Works great.
    • MoldnMaker
      • 146
      • McKenzie, TN, USA.
      Here a couple solution:
      -steel brush for loose stuff and steel wood for fine stuff(sos pads would do)
      -go to Lowes and pick up a bottle of naval jelly, it works great, but you still need to brush the loose stuff off first.
      -and lastly get a cheap sand blaster from Wal-mart or HF. They are only about $15 and good enough to get the job done if your compressor can keep the pressure up. The blasting medium can be had for less than $10 for a 20-50 lb bag.
      "Reality is merely an illusion, albeit a very persistent one." by Albert Einstein
      • Russianwolf
        • 3152
        • Martinsburg, WV, USA.
        • One of them there Toy saws
        use a wire brush to knock off the loose stuff, then get a small can of POR-15 or Rust Bullet and paint it.
        Lakota's Dad
          If you have a 4 1/2" grinder, go with a course knoted wire wheel. Makes short work of claning the surface. I will second Mike's suggestion on the Rust Bullet.
          • jabe
            • 582
            • Hilo, Hawaii
            I agree with Russianwolf, get a can of POR 15, good stuff.
            • sbs
              • Mar 2005
              • 126
              • VA
              • BT3.1k
              Any ideas?
              You can get a wooden moving dolly for $15-20 at HD/Lowes/etc.
              Same as this:
              http://www.harborfreight.com/cpi/cta...emnumber=38970
              Probably gonna take more than $15-20 of labor to clean and paint that thing...
              • brooks
                • May 2006
                • 106
                SBS has a good idea - it might be cheaper to toss it and buy a rolling thing, I saw something like that for sale at Harbor Freight. Even one pint of rust converter is $10 and I'd still have to pour primer and paint on it.
                • brooks
                  • May 2006
                  • 106
                  How much is Rust Bullet?
                  • Russianwolf
                    • 3152
                    About the same as POR-15, but no primer or paint needed. As long as you like Silver.
                    www.rustbullet.com
                    Lakota's Dad
                    • d_b_wells
                      • 13
                      I bought a drill press locally off Ebay just a couple of weekends ago and I was disappointed at the amount of rust on the thing--thought I had gotten screwed over big time. Went to Sears (I think most Sears are carrying this now) and bought the shrinkwrapped Rust-Free/Boeshield T9 pack for $20.
                      With a couple of good treatments of Rust Free and a little scrubbing with coarse, then fine, steel wool, the darn thing looks like new. Really.
                      Protected with Boeshield T9 after that (it must be some kind of spray wax in a petroleum base--like motorcycle chain wax); they sell it to be compatible with wood finishes--I hope it is).
                      There's still a lot of both the Rust Free and the T9 left. The Rust Free is acidic (Phosporic I think) so you have to have good ventilation (It's really stinky). But I'm a believer!
                      • brooks
                        • May 2006
                        • 106
                        I use Boeshield though I'm low on it right now. I'll check out the rust remover too. I didn't know it was at Sears. Thanks!
                          Biggest advantage of Rust Bullet over other products of this type is the lack of prep required. Clean the loose rust, apply first coat, wait a couple of hours and apply the second coat.
