I have just finished (I hope) my first project using shellac as the finish. It is a small box made from Mexican Bocote which I originallly thought was tight-grained but after a couple of coats of shellac I realized that I should have used a filler first. I probably have appled 12-15 coeats of blonde shellac that I made from flakes. I have sanded between coats (quite thoroughly after the first 6 coats).
I just finished sanding with 800 grit. There are still some dimples that are not competely filled with shellac but they do not shine anymore so I guess they are close enough to the surface to have been touched by the sandpaper.
How do I proceed from here? I have a satin finish which is what I want. I have been told not to put the piece on furniture for a month or it may leave a shellac stain on the piece it is sitting on. Correct? How long will it take to dry?
Should I wax the piece and when can I do that?
If I can find finer grit sandpaper than 800 should I sand further? Or use pomace or rottenstone? Or just leave it?
Thanks,
Skip
Thanks,
Skip
