I am attempting to make a pan or scoop for dust collection behind my CMS. I was thinking about opening up a section of PVC lengthwise and creating a U shaped tube that I could glue up under my CMS shelf. Is there a way to bend PVC? Can you heat PVC and get a consistent bend? Will heating PVC just melt it? My other choices might be to form this out of metal, or make a square scoop out of quarter inch ply.
Bending/Cutting PVC?
You can bend PVC, but you have to heat it to the right temperature. This can be done carefully with a torch. I don't think you are going to be able to get the sides flat for a U shape. If you do this, do it outside. PVC outgases pretty bad when hot enough to bend. I would probably get a lower temp bending plastic sheet and bend it around PVC and then have the flat sides unbent.Joe Sacher -
How about rigging a piece of aluminum or PVC gutter?...eight, nine, TEN! Yep! Still got all my fingers!Comment
PVC is a "thermoplastic" material (they make pipe by extruding the material) and is therefore reshapable (is that really a word?), using heat. But I'd be somewhat leary of it because, if I'm not mistaken, it contains Chlorine, and I don't know if it will "outgas" when heated. You could check with your local Fire Department to find out if it's toxic when it melts.Originally posted by krogersI am attempting to make a pan or scoop for dust collection behind my CMS. I was thinking about opening up a section of PVC lengthwise and creating a U shaped tube that I could glue up under my CMS shelf. Is there a way to bend PVC? Can you heat PVC and get a consistent bend? Will heating PVC just melt it? My other choices might be to form this out of metal, or make a square scoop out of quarter inch ply.
You would probably be better off using 18 AWG sheet metal for the body (Aluminum), fastened to 3/4" Plywood end plates with screws. You could then put your "pick-up" in the wooden part and probably get it built a lot quicker.Stop thinking why you can't and Start thinking how you CAN!
GeorgeComment
PVC stands for polyvinyl chloride. It contains chlorine though I have no idea whether chlorine would be released if you heated it. If you do decide to go this route, probably best to work outside where ventilation won't be an issue. Personally, I like the idea of using metal.Originally posted by gmack5PVC is a "thermoplastic" material (they make pipe by extruding the material) and is therefore reshapable (is that really a word?), using heat. But I'd be somewhat leary of it because, if I'm not mistaken, it contains Chlorine, and I don't know if it will "outgas" when heated.Comment
We have a pvc hot box for bending pvc but you could use a heat gun, blanket or a low torch.
Chlorine is not really a problem unless the pvc catches on fire probably good to do it where it is ventilated
It is easy to bend, heat it up slowly and evenly so there are not hard spots
make your bend and hold it in place for a minute to keep its shapePhil In Ohio
The basement woodworkerComment
