Patio Trolley
Good glue and a few brads should be all you need....eight, nine, TEN! Yep! Still got all my fingers! -
If you have a table saw how about some splines in the miters using wood of contrasting colour?
If you don't have a table saw then cut them carefully with a hand saw and it will work just the same. The joint will be very strong indeed with the splines glued in and particularly so if you take advantage of the grain orientation.
The splines will also look good and be very strong if you make them from a good quality birch ply 3/32 to 1/8 thick.Comment
