Yesterday I had my top bearing pattern bit in the router mounted to the router table. I was routing following a ¾ particle board pattern. I had cut the finish piece close to the line so the router only had to remove 1/8 inch at most. I was using some reclaimed lumber from the Lumber Liquidator and had some snags. Most of the routing went fine except when the router went across the grain. On the corner it caused some minor chip out which I can easily hide, but right smack dap in the middle of a 1 inch side it took a large chunk out of the wood. On the next piece I tried slowing the router down and this time the bit grabbed the edge and if I didn’t have a good grip on the piece and was using a strip of wood as a pivot point and extra support. I then tried speeding up the router with no improvement.
What should I have done, or was this an issue with the wood?
I had no issue using a ¼ inch round over bit.
