Since a real shop is not in the forseeable future, I need to increase the size of my work deck. It is now 8x12 made from a 2x4 treated frame covered with 3/4 PT Ply.
Plan is to increase it to 12x16 with a 2x6 PT frame and maybe sister some of the current 2x4's at the joints in the plywood and cross brace with the rest. I don't want to go back with the PT Ply for the deck. Even with 16" OC joists, it bows under the weight of the tools and tends to lift at the joints. My thought is to use 3/4 T&G sheathing and seal it with a porch/floor paint.
HD has 3 options available:
Behr Premium Plus Porch and Floor paint. $23 a gal with 200-400 sq ft of coverage. Requires a primer @ $19 a gal. They also recommend using a cleaner before priming, even on new wood.
Behr Deck Plus stains. Available in solid color or semitransparent. No primer needed. The solids colors are Acrylic Latex, Semitransparent is available as either oil or water based. Cost and coverage is about the same as the Behr paint but no priming.
Glidden Porch and Floor paint. $19 a gal with 400-500 sq ft coverage. Available in either Latex Satin or Polyurethane Oil Gloss. Priming is not required and the prep for new wood is sanding only.
Right now I am leaning to the Glidden for both the costs factor and the reduced labor time.
Opimions?
Opimions?
