Hi all,
Working on a pretty standard Arts/Crsfts rocker. Using QS ash.
As you'd expect the back consists of curved upper and lower stretchers with vertical slats mortised into the bottom of the top stretcher and into top of the bottom stretcher.
Still with me?
Anyway, I want to route these mortises. Have any of you built a router fence that allows you to follow the curve of a chair back stretchers?
Naturally i don't want the mortises themselves to be curved. My thought was I could avoid this by keeping them short in length, and by using a fence that, instead of consisting of the cutoff piece from the stretcher, is instead a flat piece of stock with two points (think the bottom of a capital "W") maintaining contact with the side of the stretcher.
Theoretically, if the inside radius of the stretchers is the same, and true, it seems to me like it would work.
But before ruining stock and/or fingers, I thought i'd check in here.
Am i heading in the right direction here? Anyone dealt with this challenge before?
thanks!
Still with me?
thanks!
