I allowed myself to get "talked" into re-laminating my "older" daughter's bedroom furniture.
Currently it's covered in gloss white iaminate (came that way from factory). She would like it to be matte black (don't even ask why).
Bottom line, what's easier, removing existing laminate using contact cement thinner/cleaner or running a belt sander with a 80 grit belt over the existing laminate to roughten up the surface and then cementing new laminate over it.
The furniture is solidly build, so the carcasses are in excellent shape. I'll probably replace the false face drawer fronts as the existing ones are rounded over on the tops (post formed?) and make new square edged fronts. The existing laminate is in excellent shape, no dings or loose spots, so the problem of the old layer peeling up doesn't exist.
As the furniture is frameless, there won't be any problems (fit wise) excepting another layer of laminate.
Has anyone out there done this and what's the easier way to do this job, considering that I really don't want to in the first place, but can't afford new furniture which would be the easiest way.
Thanks in advance for the help.
Bruce
Bruce
