How to do this?
    How to do this?
    LOML got a circular table top that is two halves, approx 1"thick particle board covered with melamine. That sucker is heavy. She wants to take 1 half (6'x3') and fix it to the wall downstairs so it can be folded up/down as a craft table/folding table for laundry. Wall in question is cinderblock that will eventually be covered with a texture coat but will always be masonry.
    So... I was thinking a 2x attached with adhesive+anchors then hinge the top to that somehow. Ideally it is rigged so weight sits on the 2x, not on the hinges. Any ideas? I thought about blocks on the wall and blocks on the back edge of the table (think box joint) so 3/8" or 1/2" metal pins go through both and those are the hinges.
  • Russianwolf
    • 3152
    • Martinsburg, WV, USA.
    • One of them there Toy saws
    My thought would be to attach your 2x4 to the wall and use table hinges to mount the top. If you move them about an inch and a half from the edge of the table, when it's in the up position that lip will sit on top of the 2x and the weight should transfer there instead of to the hinges.
    Lakota's Dad
    • Ken Weaver
      • 2417
      • Clemson, SC, USA
      • Rigid TS3650
      What Mike said - as long as you don't need it to fold flush against the wall.
      Ken Weaver
      Clemson, SC
      • Russianwolf
        • 3152
        I'm talking about mounting the hinges to the bottom of the table by the way.
        You are also going to need a support for when it's in the up position and just in case I would use two one folding out from each side to about 45 degrees. That way, it would be rock solid in case you ever needed to put something heavy on it temporarily.
        Of course, as you guys have seen, I tend to OVER build things so that they could never break. I'm going to be using the clothing rack I built for LOML as an engine hoist in a few weeks.
        Lakota's Dad
          You mean you can't read my mind?
          Sorry, table will actually fold up against the wall and will fold down flat when you want to use it - it will be mounted over washer and dryer.
          • Russianwolf
            • 3152
            okay, the difficulty level just went up, but.......
            dual pin table hinges. space them to the outside edge of the 2x and on the edge of the top. You'll wind up with a gap at the back when it's down and and about 3/4 unch sitting on the 2x for support. Ut should fold up against the wall nicely though. They will of course have to be mortised in so that the top isn't resting on top of the hinges.
            How's that.
            Lakota's Dad
              Mike,
              Works for me and I won't worry about a 3/4" gap at the rear of the table.
