Is Spar Varnish same as Spar urethane?
  • David Coleman
    • 20
    • Rochester, MN, USA.
    I would like to try hand rubbing spar varnish as a finish, but all I have is spar urethane. Is that the same?
  • Tom Slick
    • 2913
    • Paso Robles, Calif, USA.
    • sears BT3 clone
    nope, varnish and urethane are different but you can rub on urethane by thinning as an alternative.
    http://www.valspar.com/val/resident/manowar.jsp
    http://www.minwax.com/products/protective/helmsman.cfm
    http://www.acbs-bslol.com/Gadgets/Urethane.htm
    • David Coleman
      • 20
      Thanks, Tom, after reading your helpful links, I decided to return my unused urethane and find the varnish.
