In the new issue Vol 15 issue 86 of Shopnotes I noticed an interesting article on working with MDF. It suggests using drywall joint compound to seal the porous edges so it will take paint better. Since I am currently needing to paint some plywood I thought I'd try sealing the edges of it so I did. I haven't yet painted it but that compound sure seals it good. It fills up all those hundreds of little tiny tiny voids. Unless it doesn't come out well after painting it it sure seems like a good idea that I'd pass along. Anybody ever do this?
MDF edges
I read the same article but was wondering if the joint compound would be prone to flaking. It may be good for filling voids but if the compound is on the surface and painted over, it could be easily damaged.
________
Ocean View Condos PrathumnakLast edited by newbie2wood; 09-15-2011, 04:50 AM.Comment
I don't think I'll have a problem on flaking. I spread and pushed it into the holes with a credit card and then wiped it off with the edge of the card so it really took it all off except for what was left in the tiny pores. I'll let you know how it turns out.May you die and go to heaven before the Devil knows you're dead. My Best, MacComment
joint compound
I've been using joint joint compound to patch all sorts or nicks and dings on interior doors for years. For some reason my tenants bang up the doors in my rentals. Skim coat, sand, prime, and paint and it's done. I've never had it fail and when you consider how well it holds up on the walls there's no reason it should.
JanComment
Mac,Originally posted by lcm1947In the new issue Vol 15 issue 86 of Shopnotes I noticed an interesting article on working with MDF. It suggests using drywall joint compound to seal the porous edges so it will take paint better. Since I am currently needing to paint some plywood I thought I'd try sealing the edges of it so I did. I haven't yet painted it but that compound sure seals it good. It fills up all those hundreds of little tiny tiny voids. Unless it doesn't come out well after painting it it sure seems like a good idea that I'd pass along. Anybody ever do this?
Did you ever get around to doing this. It sounded interesting and I was wondering if it worked.Thanks,
PeteComment
One of the worse things you can do to MDF is get it "Moist"! MDF is NOT even close to being water resistant!Originally posted by Boomer_01Does the water in the joint compound cause the plywood to swell? I can see there MDF probably wouldn’t expand from the moisture because it is permeated with adhesive, but I would be concerned about plywood. Boomer
There is a product out that IS water resistant, it's made from Wheat Straw and they use an adhesive that contains NO formaldahide (sp). Used to see it used all the time on a WW show called "Router Workshop" (not on locally anymore
GeorgeComment
