Any recommendations on caster types for a mobile bt3100 base similiar to the one in the "articles" by Rod Kirby with the 4 drawers below the saw.
Which Casters?
Tags: None
I'd suggest using a "double-locking" type of caster...these lock the wheel from rotating as well as swiveling.
I used these from Grizzly on my mobile base and have been happy.
They go on sale from time to time, but even their regular price isn't too bad when compared to others.
I used the 3" or 4" ones, but I wish I would have used the 5". I don't have a lot of weight on my mobile base now, but eventually I'll be adding some storage. When I bought the casters, I didn't factor in the amount of weight that would be added by drawers and their contents.Mike
Drywall screws are not wood screws -
I just started using my newly made, not-yet-complete mobile base. It's 4.5' wide x 2' deep, so about the same size. I made it with swivel casters in back, and double-locking casters in front.
I've since decided that it's not as rock solid as I'd like. Even when fully locked, the casters have enough play in them that the base will wiggle too much for my taste.
So, I added a couple homemade leveler thingies, one on each side in front. It's solid now!
So, that's the advice you didn't ask for (you're welcome!
). Here's the advice you did ask for:
I used these. I thought they might be a little light weight, but they seem fine.
Regards,
TomComment
Hello Tom,
At a risk of sounding like an AA-confession - I just started using my newly-made, not yet complete mobile base. The base is 72"x24". I made it with swivel casters in back and double -locking in front. I have a wide table kit, so the base is bigger. I got the industrial casters by chance - a store nearby was moving and running fixture clearance. I picked up a mobile display cart with those casters. They have heavy duty 5" wheels. Unlike conventional woodworking casters they don't mount with screws from under the base. These have threaded stem. The base is very heavy but rolls easily when casters are unlocked. With locked casters it is stable.Alex VComment
I have the 4" casters from Woodcraft. It is a little pricy but very nice. If I was to do it again, I would go with Grizzly. I think their casters should work fine.
________
HURT FROM PAXILLast edited by newbie2wood; 09-15-2011, 04:46 AM.Comment
i got 2 dozen off ebay for about $50 or so. theyve worked out jsut fine,though i was concerned at first because the shape is that of a rollerblade wheel,not a flat tread which'd give more surface area.
though i havent had any trouple with them if i were to get them over again i'd probably rather have flat tread for theoretically more stability.
for bigger tool benchs etc i do have bigger flat tread wheels that i also got on ebay at a good bargain.
make sure you get " total lock" style so it locks the wheel and the swivel.namaste, matthew http://www.tribalwind.comComment
I'm with WOOD on the LV casters. These are really nice casters. Less $ and better quality than the Shepard ones sold at HD and such.
I've also used the no-name (AKA Asian made) ones from House of Tools with good success so far.
On a quality workbench I will use the LV ones though.Brian
Welcome to the school of life
Where corporal punishment is alive and well.Comment
Casters is an area wher it is not advisable to cut corners. I tried to use some from the Lowe's at about 2/3 their rated capacity. Rolling was acceptable but the bearings in the swivel were garbage.
For lighter applications, I use the Grizzly. For heavier loads, or better stability needs, I buy from Darnell-Rose. With shipping, about the same as Woodcraft but the quality is higher.Don, aka Pappy,
PlatoComment
Do all 4 have to swivel?
I have not built my mobile base yet, but would it not be a better idea to have locking swivel wheels on one end of the saw, like under the far right side, and then under the blade end simply put to straight wheels, and have them pointing perpendicular to the blade.
This way when feeding lumber through the saw, you will be going against the direction of the wheel helping it stay in place.
When you need to go mobile, you simply steer from one end. It does make the base a little bit more of a hassle to move, but far more stable when it needs to be.
Just an idea.
LeeComment
I won't try to tell you which to buy but I sure can tell you which ones not to buy and I'm not picking on HD or Lowes.
They lock up pretty good when at the store and trying to spin them by hand but under a table or cabinet with some weight on them they will move on you.
May you die and go to heaven before the Devil knows you're dead. My Best, MacComment
