Face gluing 3/4" ply
  • newood2
    • 600
    • Brooklyn, NY.
    I want to glue two pieces of 24" X 30" ply together for a 1.5" thick top. How can I make sure the center of the sheets are glued? Normally I would clamp around the edges and use screws in the center, but only if I'm laminating. I'm thinking of using 1.25" screws from the underside but afraid of the risk of not enough grip or them popping out on top.
    Do you have any ideas?
    Howie
    Plywood panels will almost always have at least a small amount of "crown" in them. Ergo, apply glue to the convex faces of the two panels, sandwich them together, and apply clamps around the outer edges. With the crowns facing each other, the panels will first touch each other out in their middles, and as you apply clamping pressure around the edges they'll pull together, thus neatly cancelling out the opposing crowns and holding the completed assembly flat.
    Another trick, especially useful as the panels get larger, is to use cauls that have a slight amount of camber along the edge that mates to the workpiece. It doesn't take much ... 1/8" of curvature over 4' will do. The principle is the same as the above: the caul first contacts the panel out in the middle, and applying clamping pressure at the ends pulls everything together, nice and flat.
    • sacherjj
      • 813
      • Indianapolis, IN, USA.
      If you have a side that won't be seen, the easiest is to use some 1-1/4" screws. I've joined two full 4x8 sheets of 3/4" with 1-1/4" dry wall screws. I drove them in enough to countersink just below the surface. Then I glued formica, or whatever laminate it was, over top of the screwed side and the sides. The bottom looked perfect and the panel has stayed nice an straight for the last ten years. The key to working with 1-1/4" screws is be very careful about not letting them counter sink far. I found they still held enough if I pushed the plys together when screwing them in. I also left the panel flat until setup properly.
      Joe Sacher
      • scorrpio
        • 1566
        • Wayne, NJ, USA.
        Park your car with one of the wheels sitting directly on panel center...
        If this is going to be a router table top, you are going to be making a hole in its center anyway. Make a hole before gluing, and clamp through it. The hole should be smaller than its final size - so you can trim it. If this will be a stand for some tool like a mortizer - it will have holes for bolting the tool down. Again, predrill the holes and after applying glue, bolt the panels togeather. Be sure to use large washers.
        • newood2
          • 600
          • Brooklyn, NY.
          Thanks guys, I went with LarryG's idea and it worked out pretty good.
          Howie
