I installed a piano hinge on a full-overlay cabinet door. I routed out a mortise for the hinge, no problem there. I placed the face frame and the door frame side by side, and put a spacer in top and bottom so the two parts were the same distance apart, and then clamped down the two frames to keep the alignment. I made sure the hinge was square when I made the pilot holes.
After I installed the hinge and closed the door, the frame and the door were not aligned properly, ie the were not square to each other. So the door frame on the side opposite the hinge extends past the face frame. It would be OK, I guess if it was straight, but it isn't. It extends more at the top than at the bottom, so I can't just plane down the door stile to make it fit properly. Ugh.
Two questions:
1) Where did I go wrong?
2) More importantly, what's the best way to fix it?
Thanks,
Tony
Two questions:
Thanks,
Tony
