Where is my Formby's Tung Oil?
  • Modfatha
    • Nov 2004
    • 64
    • Modesto, CA, USA.
    Does anyone know if lowes has stopped carrying formby's tung oil?
    I started finishing a project with it and ran out and I cant seem to find it anymore. I wanted a tung oil finish and I like the varnishy poly-like coating that formby's gives. Anyone know where I can buy it at anymore?
    \"Substituting caffeine for sleep since 1999.\"
  • WayneJ
    • 785
    I got some earlier this year at Wal=Mart.There prices seem lower than H=D. Min Wax poly was cheeper Also.
    Wayne
    Wayne J
    • wassaw998
      • 689
      • Atlanta, GA, USA.
      You can find it on the internet if you cannot locate it locally, do a google (heres and example: http://paint-and-supplies.hardwarest...sh-260851.aspx ). Last I looked our Lowes still had it.
      Chris
        • 8801
        Josh,
        The reason that you get the varnishy poly like coating is because that is mostly what it is. If the can has the word "Finish" after Tung Oil, it probably contains little or no tung oil. They get away with it because the focus is on "Finish". I do not remember about Formby's specifically.
          Lowes and HD have it here.
          ken
          • Modfatha
            • Nov 2004
            • 64
            • Modesto, CA, USA.
            quote:Originally posted by leehljp
            Josh,
            I realize this but I still like it... do you think its not as good cause it doesnt ahve as much real tung oil in it? I know it seems pretty durable and very visually appealing
              • 8801
              I agree with you that it does have a good finish and so do some of the other brands. In many ways TO "finishes" are just as good as other finishes in many cases and better in some. However I will say from my experience that there is a difference and real tung oil finish, when properly, done makes a special finish that is greatly appreciated in its own right.
              I have seen pure tung oil used to give a hand rubbed oil finish to some woods that is just beautiful that polys can't touch. I have also used pure tung oil finish with a couple of poly coats on top that gave the best water protection that I have ever seen or experienced with any other finish.
              I prefer poly and TO "finishes" on oak, but on walnut, I prefer oils, tung oil and others as well as polys in some cases.
              The main reason for my comments was to make a distinction for those that may be unaware that there is a difference. Again, as you said It does make a very appealing finish.
              • Jim-Iowa
                • Mar 2005
                • 769
                • Colfax, Iowa, USA.
                I work two days a week at a Walmart in the Paint Department.
                We have Formsbys Tung oil finish. As was said it is a blend of tung oil and poly. No doubt one could blend their own.
                But I have used Fromsby quite a lot and it is a good easy finish.
                My workbench is finished with his lemon oil
                Sanity is just a one trick pony. Being a bit Crazy is a wide open field of opportunity!
                • Modfatha
                  • Nov 2004
                  • 64
                  • Modesto, CA, USA.
                  Cool, thanks guys... ill have to check around this weekend for it. Gotta get my bed done this week
