Porter Cable trim saw FS
  • mikel
    • Jul 2006
    • 202
    • philadelphia
    • bt 3100
    The Porter-Cable 314 is a 4-1/2 inch Trim Saw. The corded one. The worm gear driven trim saw provides smoothness and durability that cant be beat. The rugged worm gear transmits power smoothly to the blade because the gears have the same amount of surface area contact at all times. The 4.5 Amp ball bearing motor of the Porter Cable 314 turns at 4500 RPM to quickly power through all plywoods, paneling and 1-by lumber. The Porter Cable Trim Saw will cut 1-5/16 inches deep at 90º and 1-1/16 inches at 45º. Features: Rugged worm gear drive 100% ball bearings Cuts 1-5/16" at 90° & 1-1/16" at 45° What's In the Box: Porter-Cable 314 4-1/2-Inch Trim Saw
    Includes two brand new sealed Porter Cable blades one plywood blade and one Carbide 20 tooth blade another used one of these blades on saw...
    works great. I just don't use it much. If you cut plywood this is an awesome tool... $140.00 shipped to you in the US
    This is the small corded one...
    ...michael 610-667-0950
  • mikel
    • Jul 2006
    • 202
    • philadelphia
    • bt 3100
    How about 130.00 shipped
    I found all the stuff that come with.. The worm drive grease the blade changing wrench and the instructions. It did not come with a case.
    It is really super clean...
    ...m
