WTB - Yellow key for BT3100 power switch and wrenches.
  • Rob.Hamlin
    Handtools only
    • Sep 2006
    • 1
    • Dallas Texas
    I picked up a saw on clearance, All it is missing is the yellow key for the power switch and the wrenches.
    Thanks,
    Rob
  • Bigbit
    • Aug 2007
    • 102
    • Southern California
    I checked the Ryobi Parts website at: https://www.gardnerinc.com/recons/splash-PT.php. Once you click on the "Repair Parts Catalog" button, click on the Model tab, then type BT3100 into the entry box. Two model options come up, choose the second - BT3100-1 10" (254mm) Table Saw
    You will find the switch key under "Center Table / Motor Assembly" and the wrenches under "Replacement Parts"
    Here are the part numbers:
    Large wrench: 969244003
    Small wrench: 969244004
    Switch Key: 984407-0030 - When I selected this, I got a message that the part was not available on the parts site, and to contact Gardner at 614.456.4000
    • bfrikken
      • 727
      • Michigan, USA.
      • BT-3100
      I'm actually going to guess that the saw has the original switch on it. If if does, then you may want to dig around the forums here, because there is a thread or two where people had switches fail on them. I"d read up on those, and find the post(s) from the person who sent out replacement switches. contact that person and find if your saw qualifies anyways.
      • Sid
        • Apr 2004
        • 139
        • Bloomington, IL, USA.
        • Craftsman 22124
        I sent you a Private Message on a pair of wrenches.
        Sid
