I saw this in another forum. If it's not ok to post this please just delete it. Some really good prices and I figured someone here near the area could benefit. Here's a full list he emailed someone and a link to the CL ad.
http://oklahomacity.craigslist.org/tls/317321040.html
1. Porter Cable 7310 Laminate Trimmer w/ bits. Box 45
2. Porter Cable 340 Palm Sander w/ case 25
3. Black & Decker Mouse Sander 15
4. Rotozip Master Kit, case, Extra accessories 45
5. Bosch 11234 VSR Impact Drill, Case, extra bits 60
6. Fein Multimaster Kit, case, extra accessories 75
7. 10” Straight Spokeshave. New 20
8. 6 piece Set Garrett Palm Carving Chisels 20
9. Jorgensen Miter Saw 35
10. Commercial Electric Halogen 2-Head Work Light, Stand, Case 30
11. Marples 6-pc Woodworking Chisel Set, Wood Case 35
12. Bosch Router Table/ Shaper w/ New 1619 EVS Plunge Router (3.25 HP?) w/ Bits 200
13. Milwaukee Heat Gun 10
14. Delta CP20 Air Compressor 2gal, 100 PSI 50
15. Delta 6” Variable Speed Bench Jointer w/ Stand. New 75
16. Delta 10” Unisaw. Table Estensions & Beisemeyer Fence. Extras. Excellent 900
17. Large Box of Assorted Sandpapers 50
18. Porter Cable 121 Oscillating Spindle Sander & extra spindles & sleeves 85
19. 12” Tile Cutter 10
20. 8 #2 Jorgensen Handscrew Clamps. 100
21. 2 Pony 90 deg. Cabinet Clamps 15
22. 2 Shop Fox Cabinet Clamps 15
23. Porter Cable 557 Plate Jointer Kit. New, Case, Extra Biscuits 100
24. 22 pc. Tapered Drill Set. 7 Drill Bits #5 - #12 w/ Collars & Counterbores. New 30
25. Dewalt Drill Set. 2-step bits 1/16 – ½. New. Complete. Case 30
26. Freud 8” Stacked Dado Set. Used Once. Carbide Teeth. 80
27. 10” 40-tooth Carbide Saw Blade. New 20
28. 7 ¼” 40-tooth Carbide Saw Blade. New 15
29. 10” 80-tooth Carbide Saw Blade. New 25
30. Merle HD Adjustable Band Corner Clamp. New, 25
31. Stanley/Record Bench Plane (#5?) England. New 25
32. Clifton 500 Convex Spokeshave. New. Box 20
33. Woodtech 12-pc Set Miniature Router Bits. New. Wooden Case 40
34. Woodtech 12-pc Set Small Router Bits. New. Wooden Case 40
35. 12” Profile Guage 5
36. Stanley 271 Router Plane. New 15
37. Bridge City CS-12 Comb. Square, 12” and 18” Blades. Rosewood. New. Box 160
38. Cowhide Honing Strop. New 5
39. 14-pc Assortment of Scrapers. Various Shapes 30
40. 3-pc. Screw Extractor Set. New 10
41. 7-size Tap & Die Set. New. Case 20
42. Record 151 Spokeshave. New 25
43. Veritas Scraper & Burnisher. New 20
44. Dial Guage & Magnetic Base. New. Box 35
45. Crown 4” Dovetail Saw. New 10
46. Ryobi/John Deere Yard Combo: Weedwhacker, Edger & Soil Cultivator 125
47. Powermatic-Houdale #95 24” Scroll Saw 225
48. Rigid Oscillating Spindle Sander, Extra Sleeves & Belts 85
49. 2 Post Jacks 30
50. Riggers/Climbers/Mountaineers Full Body Harness. HD. Top of the Line. New 100
51. Paramount Gas Leaf Blower 25
52. Delta GR050 Wet/Dry Tool Grinder. New. Box 45
53. Larin RBV5 5” Multifunction Bench Vise. New 35
54. GMC LF 131 6” Grinder & Stand 50
55. Oregon 27851 16” Bar & Chain For Various Chain Saws. New 10
56. Japanese Style Dovetail Saw 10
57. Japanese Style Pull Stroke Dozuki Saw 20
58. Japanese Style Pull Stroke Ryoba 2-Edge Rip/Crosscut Saw 25
59. 3-pc. Set of Pipe Wrenches 25
60. 2 2-Ton Bottle Jacks 15 ea
61. 2 12-Ton Bottle Jacks 25 ea
62. Floor Model 500W. Halogen Work Light 35
63. 2 2-Ton Come-alongs 20 ea
64. Porter Cable 843 71/4” HD Framers Saw w/ Brake, 80-Tooth Carbide Blade 85
65. Rigid 10” Radial Arm Saw 250
66. Delta 31-280 HD Sanding Center. Extra 6x36” Belts & 12” Discs. Rolling Base 200
67. Delta 12”x36” Woodturning Lathe. New in Box. Extras. (Components for Stand) 350
68. Bags of Large Assortment of Cabinet Hardware – Hinges, Pulls, Screws, etc. Call
69. TitebondII Waterproof Glue 16oz 5
70. Gorilla Glue 18 oz 5
71. DeVilbiss Air Tool Kit, New. Plus Sander & Impact Chisel Driver, Hose, etc. 125
72. Delta 8-pc Woodturning Tool Set New 35
Wood - Veneers, Lumber, etc.
73. 9 pcs. 1”x8”x 7’ Clear Teak Lumber. 200
74. 1 pc. 1”x15”x8’ Clear Oak 25
75. 3 36”x8’ Walnut Veneer 15 ea
76. 1 24”x8’ Walnut Veneer 10
77. 1 47”x32” Walnut Veneer 12
78. 1 24”x8’ Carpathian Elm Burl Veneer 30
79. 1 Assorted Veneer & Inlays 4”x8”x19” box 20
80. 6 1”x1”x19” Dogwood Turning Squares 15
81. 5 1½”x1½”x24 Red Cedar Turning Squares 10
82. 1 1”x5”x6’ Ziricote 20
83. 1 1”x8½”x5’ Zebrawood 25
84. 1 2½”x5”x5’ Cocobolo 25
85. 1 2”x8”x6’ Ash 10
86. 1 2”x6”x6’ Black Walnut 20
87. 1 1”x8”x52” Padouk 20
88. 1 2”x6”x32” Bloodwood
49. 2 Post Jacks 30
