BT3000 Parting Out
  • sclark
    BT3000 Parting Out
    I thought I could wait but I need the room in my shop. Bought new about 5 ½ years ago. I have used but not abused the saw. The saw was working great when I last used it about 5 days ago.
    Rails (2) Silver (41”) (whatever is holding the rails to saw will be included) Still attached.
    Accessory Table (with hole for router)
    Metal Router plate not used
    Dado insert (metal)
    Zero clearance plate (2) plastic never used
    Belts for motor (pair) new in package
    Saw blade guard
    Motor
    Extension rails and legs, 2 of each (rails have been cut and are 29”) Hardware inc.
    Saw table with two silver casters.
    I really don't know what to charge. Its yours if you make a reasonable offer. I can send pictures, just email me and I can send them.
    I can ship everything and will charge the actual shipping cost. I do have paypal if that makes a difference to you. Thanks
    Scott Clark
    sdclark@insightbb.com
  • FNILLES
    • 27
    • Chicago suburb
    BT3000 parts
    You have mail re: parts
    Fred
    • JSCOOK
      • Sep 2006
      • 774
      • Kitchener, Ontario, Canada
      • Ryobi BT3100-1
      PM sent ...
      • Peragro
        • 5
        Hi Scott,
        I'm interested in the rails if you still have them.
        Thanks.
        • Russianwolf
          • 3152
          • Martinsburg, WV, USA.
          • One of them there Toy saws
          I'm looking for a threaded rod from the motor assambly and the belts. Siliconbauhaus may have to help me explain which threaded rod.
          Lakota's Dad
          • thestinker
            • Oct 2005
            • 613
            • Fort Worth, TX, USA.
            PM sent for cut extension rails and legs.
            • menardyves
              Handtools only
              • 4
              • Montréal, Canada.
              PM sent for Accessory Table (with hole for router).
              Yves
              • siliconbauhaus
                • Dec 2006
                • 925
                • hagerstown, md
                The threaded part is as follows:
                The shaft looks like a 9/16"-12TPI threaded rod about 8" long, with a tapped hole in one end for the motor travel stop (limits how high you can raise the blade) and a turned-down place on the other end to mount the bevel gear. In the saw, it is mounted vertically, attached to the motor-raising bevel gear at the bottom and free-floating at the top. The threaded part goes through a threaded hole in the motor housing. The threads are used to raise and lower the motor/blade assembly when you turn the handle on the front of the saw.
                HTH
                パトリック
                daiku woodworking
                ^deshi^
                neoshed
                • kwok cheng
                  • Feb 2007
                  • 15
                  • california
                  blade guard assembly
                  Scott,
                  Do you still have the blade guard assembly (including the riving knife)? I am willing to offer $15 plus shipping cost.
                  Thanks Kwok
