WTB - Several parts
  • tryan15
    • 5
    WTB - Several parts
    I got a good deal a demo BT3100 from Home Depot but it is missing some parts. Hopefully I can find replacements for these.
    Specifically, I need:
    1) The parts associated with the locking lever on the fence (parts 19-23 on page 6 of the parts diagram)
    2) The blade height locking lever and crank (parts 32-35, 39, 74 on page 2 of theparts diagram)
    3) Accessory Table assemby. I don't actually need the accessory table as I have a stand-alone router table.
    Any help would be much appreciated.
    Tim Ryan
    Fargo, ND
    tryan@weirdworks.com
  • gjat
    • 685
    • Valrico (Tampa), Florida.
    Try just calling the customer service people and explain the situation. Tell them the parts are broken so it should be covered under the 1 year warranty even if you did buy a demo unit. I don't think it will be a problem.
    • tryan15
      • 5
      Taking gjat's advice, I went ahead and contacted Ryobi online. Not sure if this is of interest to others, but this is the coversation:
      Your Question/Problem:
      I just purchased this saw as the last one in stock at my local Home Depot. It appears to have served as a demo model or somesuch and has some issues. The cam lever on the fence is missing (parts 19-23 on page 6 of the parts diagram). The blade height and angle crank is broken and or missing (parts 32-35, 39, 74 on page 2 of theparts diagram). And the Accessory Table assemby appears to be missing. What is the best way to go about getting this corrected on this saw?
      Ryobi Response: (04/11/2006 08:34)
      Dear Tim,
      Small parts can be sent, however, the accessory table cannot. If the saw was discounted by Home Depot, then you would be responsible for replacing the missing parts. I would suggest returning the saw back to Home Depot.
      Best regards,
      Sherry T.
      Consumer Response
      One World Technologies, Inc.
      Your Response: (04/11/2006 10:03)
      Are you saying that you will replace the small parts under warranty if I ask you to? I understand the table issue and can deal with that on my own.
      I would happily return this saw for a new one, but Ryobi has discontinued this product making it unavailable to me.
      Any help you can provide would be appreciated.
      Ryobi Response: (04/11/2006 10:03)
      Ryobi HAS NOT discontinued the BT3100 table saw.
      Replacements for the small missing items with the exception of the accessory table can be obtained by contacting Ryobi customer service at 1-800-525-2579 between 8:00 a.m. and 5:00 p.m. EST.
      When I called the line I was told they would not honor the warranty for this product as it was sold at a discount.
      So, I am back to needing the crank assembly, fence locking cam and an aux. table. Any help would be appreciated.
      • Stan
        • 966
        • Kalispell, MT, USA.
        • BT3100, Delta 36-717
        Tim,
        Too bad I didn't see this message before the weekend. I just posted a Blade adjusting handle and gear shaft on eBay. (Along with another one for the BT300 that would probably work also -- minus the gear shaft).
        http://www.elksigndesigns.com
        • tryan15
          • 5
          I suspect I am the high bidder on that one right now (although I haven't hit your minimum). I will keep an eye on it.
          • Stan
            • 966
            Guess I should have looked at bids.
