SE Wisconsin - Milwaukee area. Local pick-up only.
delta 16 1/2" Floor Model Drill Press
Email: my_crib_too@yahoo.com.
I friend is selling a delta 16 1/2" Floor Model Drill Press. Very good condition. Was used in a home woodshop.
Delta 16 1/2" Floor Model Drill Press. It is a model 17-900. I used it in a home woodworking setting. I upgraded to a larger variable speed model. This is the stats: Horsepower: 3/4 hp Volts: 120/240 currently wired for 220v but can be switched back to 110v. Motor construction: Induction Benchtop or stationary: Stationary Throat capacity: 16-1/2 in. Chuck capacity: 1/2 in. Switch type: Toggle Number of Spindle Speeds: 12 Spindle Speeds: 250, 360, 410, 540, 590, 650, 1090, 1280, 1450, 1820, 2180, 3000 rpm Drive type: Belt and pulley Max spindle dist to base: 47 in. Max spindle dist. to table: 27 in. Table size: 12 in. by 12 in. Rack/Pinion Table Adjustment: Yes Length: 12-3/4 in. Depth: 25-1/4 in. Height: 66 in. Tool weight: 194 lbs. I have a few pictures available.
