I'm looking for a square foot sheet of Black 3/8" thick XX Phenolic. Similar to the type Woodhaven uses in their jigs/fixtures.
Phenolic Sheet
US Plastics carries Phenolic, but it's in sheets larger than you require. If you decide to buy a 2' X 4' sheet, you should be able to cut it into 1 foot squares and sell 7 of them to other Woodworkers for more than enough to cover your cost.
http://www.usplastic.com/catalog/pro...uct%5Fid=10288
You might be better off buying a blank from Woodhaven.
George -
You should be able to walk into a local plastics supplier and get whatever you need. From my experience, its pretty standard stuff that a lot of places stock.Comment
Hopefully you live in a better local than I do. Not a lot of folks have it, and those that do sell it by the sq ft/in and at a hefty (to me) mark-up.quote:Originally posted by burrellski
One idea is to check eBay. You'll have to filter off all the phenolic pool balls, etc., but if you pare things down by category, you can filter most of the chaff.
Ray"A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects."
--- Robert A. HeinleinComment
Our local plastics store doesn't handle phenolic. I mentioned it to the Blades'n'Bits guy who advertises on this site, and he said he had a contact in Canada (Toronto?) that could provide it at a good price. Might be worth checking with Blades'n'Bits.- David
“Be yourself; everyone else is already taken.” -- Oscar WildeComment
I found what I needed at McMaster Carr Supply. They just slipped my mind when I went searching.http://www.mcmaster.com/
John M VargaComment
You're right!
Here's the scoop on what's available from McMaster-Carr.
stock Number: 85315K116
Grade XX Black Garolite Sheet 3/8" Thick, 12" X 12"
In stock at $16.89 Each
GeorgeComment
I would consider something else.quote:Originally posted by jxyoung
Craftsman micro torque wrench $26 off. Now $48. 9/16 to 9/18
These do not have lifetime warranty, Husky@HD,and HF ones do. I have both and the Husky is better in 1/2" drive size due to 250Last edited by tribalwind; 02-14-2006, 02:10 PM.namaste, matthew http://www.tribalwind.comComment
These do not have lifetime warranty, Husky@HD,and HF ones do. I have both and the Husky is better in 1/2" drive size due to 250Thanks,
PeteComment
