I recently replaced the rusted burners and flame arrestor bars on my gas grill. It's a 4 burner. There used to be a piece of angled sheet metal that laid on top of the burners at the rear. I'm pretty sure it was used to channel propane from burner to burner so you woudln't have to light each burner individually--just the starter burner.
Anyway, that piece was toast and I don't have a replacement so I have been lighting each burner individually--kind of a pain. I do have aluminum angle iron that I could lay on top of the burners in the same spot to channel the gas.
1) Is it safe to burn aluminum in the presence of food? I know pots and pans are made of Al, but usually they're clad in stainless so they don't react with the food. People also cook on foil on the grill (I have). Are there bad fumes if you burn aluminum? I'm not seeing anything in Google that indicates there are.
2) Will I prematurely corrode the new stainless burners if they are in contact with the aluminum bar (or vice versa)?
I suppose I could buy some steel angle, too, but I've already got the aluminum.
Thanks,
Paul
Thanks,
Paul
Black wallnut
