portable generator natural gas conversion
  • toolguy1000
    • Mar 2009
    • 1142
    • westchester cnty, ny
    yesterday saw the completion of the natural gas conversion of our 4KW portable generac generator. here are a few pics of the completed conversion:
    http://www.shutterfly.com/lightbox/v...f3edf1ebadc1fb
    and a brief video of the unit in operation:
    http://www.youtube.com/watch?feature...&v=Tm3an9wGtIY
    this is the unit i used:
    http://propanecarbs.com/
    it works well, but i'd try some other unit if i had it to do again. the instructions were unclear and too brief. and one of the threaded rods that substituted for the OEM bolts that attached the carb. to the intake manifold and is used to connect the NG adapter to the carb, was defectively threaded. the kit was, however, complete relative to the crankcase ventilation connection to the carb and the third attaching bolt for the air filter housing. i give it an 8 out of a possible 10. but, deficiencies aside, it's going to be a relief when the next outage occurs of not having to search for fuel or a service station that can pump same.
  • Habe
    • 164
    • Indianapolis, IN, USA.
    • 22114
    How are you handling the exhaust from the unit? It appears to to indoors in the video.
    Habe
    • toolguy1000
      • Mar 2009
      • 1142
      nope. it's outdoors with adequate ventilation.
      • Tom Slick
        • 2913
        • Paso Robles, Calif, USA.
        • sears BT3 clone
        That's pretty neat!
        I recommend a "drip leg" where the hose connects to the house plumbing.
        • toolguy1000
          • Mar 2009
          • 1142
          thanks. it's inside just before the exit point to the outside.
