Replacing Vacuum Cleaner Plug
  • newbie2wood
    • Apr 2004
    • 453
    • NJ, USA.
    My vacuum cleaner has a 2-prong plug. The plug is damaged, and I have already clipped it off. Is it safe to replace the plug with a 3-prong plug. The reason for asking is that I have a bunch of spare 3-prong plugs at home.
    The cord has two wires (hot and neutral) but the plug has three screws (hot, neutral, ground). Can I just wire the hot and neutral to the appropriate screws and ignore the ground screw?
    Yes you can.
    • newbie2wood
      • Apr 2004
      • 453
      • NJ, USA.
      I wired the plug, and the vacuum cleaner is working again. I just wanted to get some feedback. Thanks.
      • All Thumbs
        • Oct 2009
        • 322
        • Penn Hills, PA
        • BT3K/Saw-Stop
        Just a follow-up that it is okay to replace a two-prong plug with a three-prong plug, the opposite is not true. If you have a three-wire cord, you need a plug with the ground. Using a plug without the ground may expose someone to a shock hazard.
