Many of our windows show a lot of putty squeeze out. The windows are double-pane, and on the inside there appears to be an about 1/16th gap that was filled with some kind of putty, some gray/brown, the rest dark brown (fits better with the stain but squeeze out is more noticeable). In some areas squeeze out is as much as 1/2"!
So: what might be causing that squeeze out? Is it the excessive wood movement in out Minnesota temperature and humidity extremes?
Should I just try and shove the old putty (which is still pliable) back in there?
Or remove as much as possible and replace, and if so with what product? Since the gap is pretty noticeable a colored product would be preferable.
Can I use just regular old putty? Can I add dye to it, and if so what kind?
Thanks
Gerd
Thanks
Gerd
