Lawn mower oops
  • Shep
    • Nov 2008
    • 710
    • Columbus, OH
    • Hitachi C10FL
    Fixed the mower yesterday. Thank you to all of the responses and suggestions.
    I found that the coil was not producing a spark. The coil ended up not being properly spaced to the fly wheel. Not sure if the bolts had worked a little loose or what. I also took the time to clean evertyhing. Even took off the carb while I was at it and gave it a good cleaning. Cleaned all contact points to make sure the connections were clean.
    I need to give thanks to a youtube video I found that was helpful in diagnosing starting problems on a B&S engine. That saved a bunch of time.
    -Justin
    shepardwoodworking.webs.com
    ...you can thank me later.
