So, I have a finished basement (well, mostly finished) that I have had leak a couple of times a year when it rains heavily. It's not constant that it leaks into the center of the room, but it definitely gets damp- or at least more damp than I'd like (the dehumidifier almost never clicks off in summer). There's no sump pump in the house so I obviously don't have any drainage system currently in place.
So... I'm thinking that the basement will be my first real large-scale rennovation for the house. What I'm wondering is, what's the best way to go? I'm a fan of Holmes on HGTV, but I'm not sure that I can afford the excavation + rubber + mesh + plastic sheeting + drainboard + draintile + catch basin + Sump pump solution. At least not professionally installed. I'd maybe be able to get away with DIY, but that's still expensive and I'd have to rent an excavator and hopefully not destroy my house in the meantime. I need to install an egress, so maybe I can attach the worst wall this way and do the window at the same time- either DIY or professionally.
The other solution seems to be drain board on the inside and installing drain tile. Or, I found information or drainage baseboard, which installs on top of the floor to provide a channel for the water to drain to. Or, you can try a system that coats the inside with a sealent or rubber coating.
What do you guys think? I'm definitely not wanting to invest in money and time in something that will not work- or make the issue worse (the baseboard solution involves drilling weeping hole in the block wall to allow the walls to drain easier. However, I do have to worry about budget here, since it's just me in the house and I have only my income to fund such a project.
Thanks,
Travis
Thanks,
Travis
