I have a quote from a reputable insulation contractor that I am ready to pull the trigger on. However, there is an option that I am unsure of...and I'm looking for input that anyone can provide.
At the bare minimum - I plan to have them put more insulation in the attic. Right now - I have the original (60's era) blown-in fire-retarded sawdust that is just barely covering the joists. It's pathetic, and I've been heating/cooling the outside world for quite some time - R20 at best, and that's generous. Their plan is to do the appropriate sealing, ducting, and blocking in order to blow in fiberglass to bring the level up to R50. This should make an immediately recognizable difference in heating and cooling my home from what I am told - and I believe them (am I wrong to believe them?). They will do some other specific things with regards to my house construction that made sense to me as both of us worked the flashlight around the attic, but I can't describe them sufficiently here. I trust the contractor - that's not the issue.
The additional option is to seal the interior and exterior 'top walls' with expanded urethane foam - prior to the attic insulation work. The estimator said it would improve efficiency - but admitted that it was probably only another 10% - and was hesitant to recommend it. Doing this would double the cost of the insulation work. One of my coworkers thinks I'm a fool for not doing the 'top wall' sealing....to be fair, he's completely 'gutting' and rebuilding his home - and he's planning on doing the 'top wall' sealing himself.
Does anyone here have any input regarding sealing the 'top walls'? I don't plan on being in my house more than 5 years and would rather spend the money on 'visible' improvements.
Thanks for any shared wisdom here,
coryb
coryb
