Flies in the house, and now I know why?!!
  • radhak
    • 3061
    • Miramar, FL
    • Right Tilt 3HP Unisaw
    For the past few weeks, we saw a lot of fruit-flies in and around the kitchen. We don't use the AirConditioner all the time, keeping windows open instead, so we were thinking that must be problem. Not that we had any explanation for why only now...
    This morning LOML is upset that somebody must have broken some vinegar bottle or such in the refridgerator, because she could see liquid seeping along it, outside. I checked and did not think it was vinegar (and nothing inside seemed to cause the leak).
    In a sudden burst of genius, I decided to move the 'fridge out - with a lot of effort. And whaddya know? The water connector for water/ice-tray is a 6' long narrow plastic tube, and it had a miniscule leak on it ! The area behind was all soggy and muddy with dustballs. I immediately tried to tape the leak, but decided to run to HD and got a replacement rubber tube. Replacement took all of 10 minutes, but the cleanup was longer. I still think we got off easy, seeing that the pipe could have burst fully and we could have had a flood indoors!
    2 years ago a maintenance guy had said I should replace the pipe with a copper one, and he'd charge me $200 for that. I'd rather live with do-it-myself for the $8 for material .
    And the flies are already disappearing - thankfully!
    - Aristotle
    Assuming you are talking about the supply from the wall to the fridge, why not replace it with copper yourself? That is all I have ever used and never had a leak.
      • 8777
      We had some fruit flies once (on a continuous basis for several weeks) and then discovered that they were coming from the soil of a potted plant that a 'friend' had given us.
      • radhak
        • 3061
        • Miramar, FL
        Yes, that is the one, and I did consider copper, but have to think it thru :
        (a) The copper at HD was just a long tubing; I'd have to do the threading to put on the nuts
        (b) My 'fridge needs to be pulled out almost 2 feet before I can get in there to access the fixings. Not sure how a stiff copper pipe would behave there.
        Oh - I better keep an eye on that new cactus plant she's got on the counter lately !
        - Aristotle
          We don't always use the A/C either, but don't you have screens? The copper tubing can be a simple compression nut connection, and if you leave a small coil, you can manipulate the fridge. If you're careful, the copper bends easily.
