Woke up Sunday morning and found that rather than going kayaking I was in for a day of plumbing. Tepid water on the laundry room floor signaled the demise of out water heater. I don't know if it started leaking around the inlet/outlet pipes or if the neoprene washer in the connection failed. I suspect the washer as when I removed the connector nut the washer was brittle. However the top of the heater was all rusty and the insulation soaked. It was the original for the house making it about 19 years old and time to be replaced. That's the bad news, the good news is I discovered SharkBite fittings for copper, and apparently several other pipe possibilities. I used the torch only to remove the old fittings and then cleaned up the end of the pipe. Pushed the fittings on, one end of the water heater flex connector came equipped, and screwed the connector on to the new heater and I was done. Draining and getting the old one out took the most time, after the trip to get the new one at HD and the subsequent side stops. So far no leaks, didn't set the house afire with the torch and didn't hurt myself.
on the Sunny Oregon Coast, clear blue sky's and a high of 70 today
