Compost Tea?
  • JoeyGee
    • 1509
    • Sylvania, OH, USA.
    Compost Tea?
    Does anyone here use compost tea on their lawns? I saw it used on ATOH the other day. They use it at Hahvahd, and they showed roots from grass up to 8". I know they are pros, but anything close to that would be awesome.
    From what I have read, one of the great advantages is water retention and as a result, less watering and more drought prevention. Our water rates are high and getting higher, so I am very interested.
    As long as you have good compost, it seems to be a fairly easy and cheap process. Maybe I'll try it on a section of lawn to see if it works.
    I dunno... http://www.finegardening.com/how-to/...mpost-tea.aspx
      I've seen grass with roots 6 feet deep, and without tea, so I doubt if tea is necessary...
        Shouldn't the tea for grass have to be green tea?
        • jking
          • 972
          • Des Moines, IA.
          Aerating your lawn will stimulate root growth & help get water where it needs to be. Probably a bigger difference maker than what type of fertilizer you use.
