I'll be removing the T1-11 and replacing it with Hardiboard. While I have the walls down to the studs I would like to improve the R factor in the walls. Can anyone comment or steer me to someone who can regarding the method, materials and feasability of such a project? I've had suggestions from adding on to the studs to the equivalent of 2"x6" and top off the current insulation to removing the old and less efficient insulation and spraying in some cellulose, top off and over the studs with rigid foamboard with a reflective barrier and attach the cement board over that. I'm leary of hanging the top layer to foam - you know, gravity.
TIA!
TIA!
BTW, the overhang is 16" wide.
