I've got a concrete patio that's about 45 years old. It was done in two halves at different times. There was no attempt to create a smooth edge on the first pour or the second pour, creating a clean seam. One is just butted up to the other.
Well after all the years, surface edges have feathered back (about 3/4" on each side) from the joint, and one side is about 1/2" higher than the other. I would like to level out the joint which is about 18' long. If there was something like a masonry belt for a belt sander, that would be great.
I had a few thoughts. I could just grind a slot and install some sort of joint track, like for expansion/contraction. I really prefer to have just a clean seam if possible.
Any thoughts?
Any thoughts?
