An Electrical Puzzler
    I am finally upgrading my house main panel tomorrow. I am extending the existing circuits to the new. I will run new wiring directly from the meter to the new panel. The existing meter to panel wiring is 4/0 aluminum - 2 hots and a braided bare ground/neutral. The new wiring will be 2/0 copper, 2 black hots and I have remarked another white for the neutral. So the question is, why is the existing neutral allowed to be bare? As a current carrying conductor should it not be insulated? I posted this on another forum and got a PM saying I'd annoyed an electrician because he didn't know the answer.
    If this turns into another copper/aluminum debate I am deleting those posts. I chose copper for the new run only because it is smaller diameter and easier to work with.
  • KLF
    • 98
    • Barrington NH
    • BT3000 (of course)
    I'm not an electrician, so this may be not be 100% correct.
    The neutral on your service is actually a grounded conductor. I believe if you trace the existing one it will be connected to the ground rod at your service entrance. That's how mine is, at least. The neutral is split off the ground as a seperate conductor inside your main service panel. If you look carefully the neutral bus should be strapped to ground inside the panel. This is only true on the main panel, if you have a sub-panel or something like a generator transfer switch panel, the neutral and ground are maintained as seperate conductors.
    • master53yoda
      • Oct 2008
      • 456
      • Spokane Washington
      is the bare conductor warped around the other two and inside an insulation.
      The above configuration is called service entrance cable. the ground/ neutral do not become separated until they hit pass through the neutral/ground bar at the service panel. they are normall run insulated in some form once they enter the structure. you normally don't see bar ground/neutral wires inside the conduit of a service.
      Art
      • master53yoda
        • Oct 2008
        • 456
        separate question. are you running the wires between the meter and main panel in conduit or are the three wires running in open air. also are the aluminum and copper wires being connected where the can physically touch each other.
        Art
        • tseavoy
          • May 2009
          • 200
          • Nordland, Marrowstone Island, Washington
          • Older 9 inch Rockwell Delta (1960?)
          KLF is right. The neutral is ground, the ground is ground. It's sort of a redundant thing. The neutral is tied to the ground at the main panel and the ground is tied to a ground rod.
          Wiring in houses often do not distinguish between hot and neutral, so the neutral in houses is insulated. My previous house in Seattle had knob and tube wiring and non polarized outlets, so it was anyone's guess as to which outlet hole was hot.
          Tom on Marrowstone
            If this was my electrical project, I wouldn't proceed with any advice I would get from an online forum. I would trust a licensed master electrician in my area. Even if I didn't hire the guy to do the work, I would pay for a consultation.
              I didn't look that closely, but it probably is. Your second paragraph makes sense and is consistent with my understanding of electricit/wiring in general.
              Running through 2" close nipple. I am replacing the SE cable, not extending it. Only extending the circuits. Aluminum and copper wires can't touch each other. Google Polaris splice. Those things are tres chic but according to the inspector and the electrician I consulted, worth it. I will find out tomorrow.
              • michael_p30519
                your bare ground/neutral was a bare ground not a neutral older homes did not have neutral in new homes you have a ground & neutral
                • eezlock
                  • 997
                  • Charlotte,N.C.
                  an electrical puzzler
                  Crokett, What I remember from my electrical school training...many years ago is this. The neutral is the "grounded conductor"...meaning it is the electrical return path for the current in the system. A bare twisted (braided type) ground is the "equipment grounding conductor" that is physically connected to a driven ground rod, what it does is provide protection for the electrical service and equipment connected to it if the need arises. It is also connected to the building water supply by a #4 awg bare copper wire and ground clamp also, this provides a secondary grounding method for the system. Also, a neutral can be (1) wire size smaller than the hot conductors
                  without any loss of protection to the system.
                  The neutral can be solid white, gray or white stripe on a black covering to identify it from the current or "hot " conductors.
                  At service panel, grounds and neutrals can be connected to the same bus bar.Any set of disconnects( fused or breaker type disconnects) after the main service disconnects are classified as sub- fed panels and as such must have an isolated(separate) neutral bars away from the equipment ground bars. This is where you get the separation of neutrals and grounds.
                  Hope this isn't too confusing and maybe it will help.
