Not really home maintenace - snowblower engine question
  • newbie2wood
    • Apr 2004
    • 453
    • NJ, USA.
    I have Troybilt snowblower with a Tecumseh engine that won't start with the choke on full. It starts fine with the choke off or in 1/2 position. I purchased the snowblower a little over two years ago, and I can't recall if the snowblower operated like this two years ago.
    I google the problem and found most people have the opposite problem with their small engines, i.e., the engine only starts with full choke.
    Do I have problem that needs to be addressed?
    ________
    couple Webcam
    What's a snowblower?
      You don't want to know. The truth would probably give you nightmares.
      • sweensdv
        • 2873
        • WI
        • Baileigh TS-1040P-50
        Until it won't start at all I don't see why you should worry about it. Of course it will have snowed 18" of wet heavy white water the night before that morning that it won't start.
        • BobSch
          • 4385
          Around here, a snowblower IS home maintenance!
          Bob
          • Habe
            • 164
            • Indianapolis, IN, USA.
            • 22114
            Sounds like it's not cold enough to need full choke yet.
            Habe
            • Hellrazor
              • 2091
              • Abyss, PA
              • Ridgid R4512
              The only way I would consider that a problem is if it doesn't want to start in cold weather...
