Note: This was also posted on Woodnet.
In a previous post, I showed off my porch addition:
http://www.bt3central.com/showthread.php?t=46243
Part of that construction included a new screen door. The new door was built to match an
existing one. If you can believe it, the door only took one weekend to build--not including
painting. It was made really easy with my jig below.
I bought pre-primed 5/4 wood from HD. I was very happy with it. Very flat and true
and not too badly priced. It came in super long lengths so I had very little waste. The whole
door frame (except the bottom grid) is loose mortise and tenon. First I cut all the parts to size.
I made a router mortising jig more than 4 years ago--before I ever saw the Mortise Pal.
This is the bottom view. The jig allows for a 5/8" collar to ride in a slot. It will cut a max 1/2"
wide mortise. A 5/8" piece of wood is put in the slot and then the tall fence is adjusted in or
out to determine where the mortise will be cut. Because I was using thicker wood than my
normal 3/4, I used the flat face of a square and my table saw wrench to offset the fence to the
right spot.
This is a top view of the jig. The parts labeled "A" have slots routed in the them. They slide
in and out to adjust the mortise length. Parts A are held in place by tightening 2 bed bolts
labeled "A" in red. The fence is held securely by tightening the 2 bolts
labeled "B". Believe it or not, when I built this thing, I didn't put a lot of thought into it. I am
not a WWing savant. Just lucky in this case. The jig is clamped to the piece in my bench vise.
Ready to route. During routing, I keep my DC hose tucked under my arm. After routing a pass,
I lift the bit up, move the router out of the way, and suck out the chips. Lather, rinse, repeat
until you get to the desired depth. Sorry, but I have no mortise pics. They come out perfect,
though.
The trick with this jig is to always reference the fence from one face of the work--
there's no guarantee the fence is perfectly centered. No problem. Just make pencil marks.
I made loose tenons from some 1/2" thick scrap. I rounded them over with a block plane and
tweaked each one to fit.
The bottom grid was made with by half lapping 2 pieces.
Here's the dry fit. Dang if this wasn't one of my most square glue ups. Gotta' love that jig!
I decided to route grooves and affix the screen with splines. No problem for my little Grizzly
trim router and guide. Woops. I shouldn't have routed through that section. That's what
wood filler is for! Too bad I already painted the door.
Now the poly screen is set in place. The screens get nice and tight.
I covered up the spline with some homemade trim tacked in place.
Here's the finished door in its final resting place. I had to demo the old screen that was in the
place of this door and frame it out for this door.
Paul
right spot.
though.
The trick with this jig is to always reference the fence from one face of the work--there's no guarantee the fence is perfectly centered. No problem. Just make pencil marks.
Paul
