Splicing #2 Wire Underground
    Is this acceptable? I don't think it is but even if it is it isn't desireable, at least by me. I have approx 40' of #2 - 2 hots, neutral and ground - that came with the shop. I need about 55, give or take. So should I sell what I have and buy long enough to get there or can I bury a splice? I don't really want to bury one, especially for wire this big. I'd keep it except I don't see me ever using it.
  • Daryl
    • 831
    You can get water proof splices, I have used them in water wells to hook up a submersible pump. Alternative is to bring it up above ground, add an outlet there, with gfi of course, for whatever reason you may want one.
    • Tom Slick
      • 2913
      • Paso Robles, Calif, USA.
      • sears BT3 clone
      I'm not sure but I'll bet you would have to install a vault at the splice.
      • Mr__Bill
        • 2096
        • Tacoma, WA
        They make a direct burial splice kit.
        But
        For me, where ever their is potential for trouble at some point it's going to happen, I would sell what you have and buy new.
        Bill,
        • woodturner
          • Jun 2008
          • 2049
          • Western Pennsylvania
          They sell lots of things that are not "legal" to use.
          NEC requires all splices to be made in a box - it's not legal, per NEC, to bury a splice.
          • gjat
            • 686
            • Valrico (Tampa), Florida.
            Splicing is allowed by NEC, and you're right, it must be in a pull box (vault). My company does street lighting and we make splices all the time. However, I don't think it's cost effective for the little bit of wire you're talking about. Splices are inerently problematic, especially for power feeds. We work mostly with higher voltages then 120/240v, but I personally would NEVER splice in a residential situation. Splices often fail over time and you're risking an uneccessary hazard to save a few bucks.
              Probably ought to go with your gut and not do a splice.
              Is this the run going out to your shop? What sort of load & voltage drop are you designing for?
              If you buy new, I don't think you need anything near as large as a #2. I figured you were using #2 because you already had it.
                I won't do a splice. The panel in the shop is rated for 100A. You are right I was using #2 because that was what he had. I need a circuit for lights, 2 -3 20A 110V circuts for tools and then a 220V circuit or two. I have a planer that runs at 220 and may or may not have a window A/C unit there in the summer. My current basement shop has 1 light circuit 2 20A circuits and I do just fine. My planer is at my dad';s but will get moved back when the new shop is up.
                • L. D. Jeffries
                  • 747
                  • Russell, NY, USA.
                  For what its worth! My shop is about 30 ft from the main breaker box in the house. About 10 yrs ago some stupid (on my part) digging I managed to cut one leg of the buried cable. Put in a "vault" box splice. Never have had a problem since!
                  RuffSawn
