In the next couple months I'm going to need to repaint my house. It's primarily a dark red color, with a lot of white trim. This will be my first full-scale experience painting a house, so I've got a few questions (growing up, my folks' house had vinyl siding, and I've rented up until a few years ago, so it was someone else's problem!)
I plan to scrape and sand a lot of areas where the current paint is chipping and/or beginning to peel. Will I need a primer coat before the topcoat, or should the paint that doesn't get peeled away be enough to serve the role of a primer?
Any rules of thumb for estimating how much paint I'll need? I'm terrible at this type of estimation on interior projects (I always under-buy), so give me the estimating-for-dummies answer!
The house, FYI, is a two-story, probably closest to call it a colonial. Mostly a basic square, with a couple bump-out bay windows. I've also got to repaint the soffits (roof overhangs on all sides - more or less a pyramidal roof)
Any general advice? How best to deal with painting around power lines (I assume I can just contact the utility to turn off the juice while I work - correct?). Anything I might not be thinking of?
The house, FYI, is a two-story, probably closest to call it a colonial. Mostly a basic square, with a couple bump-out bay windows. I've also got to repaint the soffits (roof overhangs on all sides - more or less a pyramidal roof)Any general advice? How best to deal with painting around power lines (I assume I can just contact the utility to turn off the juice while I work - correct?). Anything I might not be thinking of?
