I have a recurring issue with my bathroom drain. The bathroom is located on the ground floor & has a sink, toilet, and tub. These drain into the main soil stack, the sink & toilet have maybe two feet of drain line to get to the stack.
About twice a year, the sink starts to drain kind of slow. The drain slowly gets worse until it won't drain unless it sits for several hours. The culprit is a buildup of sludge on the inside walls of the pipes. When the drain starts slowing, I remove the trap & clean a pretty thick layer of sludge buildup from the trap. Then I run a snake through the drain line, usually about 5'-6'. Re-install trap & run water through the line. I may have to repeat this again to get the line completely clear as sometimes stuff I knocked loose from the drain walls gets flushed partway through the drain & it clogs.
What I'm looking for are ways to prevent this buildup from happening. Would it help to periodically fill the sink completely full & then drain to get some good water flow to flush everything? I've tried dumping drain cleaner down the drain periodically, but, it doesn't seem to make a difference. I will continue to run the snake through the drain every 6 months (or when it starts to slow down), but, it would be nice if I could find a way to prevent the buildup.
