I put the attic stairs in today. I intended to add some 2x4s between the trusses that the stairs are hung from and the ones to either side to help carry the load. On one side I discovered a 2x6 that is the top plate for the wall underneath that the 2x4s would have to be notched over. So...
Double up on the 2x4s and notch them both?
Use a notched 2x6?
Or the option I like best, notch the 2x4, install it then install another flat over the top that spans the trusses.
Use a notched 2x6?
