Water Hose Automatic Recoiler
    I'm looking for a good water hose automatic recoiler for 3/4" hose with at least 50' - 100' capacity. Any suggestions?
    I've got 2 of these. Works pretty well, but you will work up a sweat pulling the hose out fully. Time between battery recharges varies, depending on how often you use it. I probably use mine once a week, and usually recharge once every couple of months. You may want to get a couple of those "pulley-spikes" for retrieving the hose around corners or planter beds.
    • MilDoc
      Takes 5/8" hose, runs on water pressure to rewind. Works great! Had one for 5 years with no problems.
      http://www.amazon.com/Classic-Powere...5657109&sr=8-5
        I had the 125' version of this one, Paul. Mine sat on my driveway, between the 2 garage doors, and what I didn't like was that there was no place to put the discharge water that flows when it rewinds, other than let it go right into the driveway. Made for a sloppy mess, and lots of tracks into the house that got me in trouble. And it quit working after a little over a year. Glad you've had better luck.
        • sd
          • 66
          You might find something you could use on one of these sites:
          Hosemaster
          Reelcraft
          -- Steve
            I don't think I need a power out/in type reel, but maybe for that length I might. I was thinking just maybe a spring loaded return of some sort. I don't mind pulling the footage out, but handcranking the return would seem to be frustrating.
