Being that carpet requires stretching when it is laid, if a room is 12'4" wide, can a carpet 12' wide be stretched enough to fit?
laying carpet
Tags: None
WELCOME TO THE FORUM
I would think that if it didn't stretch, they would use a heat seam tape, and piece it in. A good installer can do it well.
Welcome,
I don't think carpet will stretch 4 inches, but I'm not an expert.
why don't you fill out your profile and introduce yourself.Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas EdisonComment
No, I'm afraid not, ranchergirl. Even with a loose weave backing, you wouldn't get to stretch it more than enough to put some tension into the weave. 4" is definitely not possible, but an ironed seam will work OK and be invisible if done properly. Welcome along, BTW!Originally posted by ranchergirl... can a carpet 12' wide be stretched enough to fit?
Ray.Did I offend you? Click here.Comment
The good news is that, in a year or two, the 12' carpet probably will reach.
And you could also build out the walls 2" on each side...
