A friend asked me about identifying a load bearing wall. He wants to take one down and wanted to know if it was load bearing. He does not know if his roof framing is joist/rafter or trusses. He does know the wall runs perpendicular to the framing. The layout of the building is it is approx 15x25. Along the 15' dimension there is a wall that runs parallel to the roof framing that divides it in to 2 spaces approx 15x14. and 15x11. There is a wall that then runs perpendicular to the roof framing that divides the smaller space into 2 spaces. It is this wall he wants to remove.
Assuming it is trusses, then by definition the wall is not load-bearing correct? Also, since the wall does not run all the way across the building then it probably is not load bearing, correct? Is there a way to tell by climbing into the attic and looking at it?
