The pull starter only pulls in the clockwise direction (lookin' at it), and it was frozen. So, I removed the sparkplug, and squirted in WD40 on top of the piston. Then removed all the shrouding that housed the recoil mechanism. Couldn't get it off completely because the carb housing was in the way. I thought if I removed the carb, The gasket was likely to disintegrate. So, I got the recoil housing out far enough to get to the flywheel. It actually would turn by hand backwards, but not forward. So, I kept workin' it and the WD40 musta did it's thing, and it finally turned to the right.
Put it all back together, and it started up a huffin' and puffin' until it ran clear. Thanks for all the help and suggestions.
