Buying a new house and the boiler is fromo 1983 or so. Still works, and not a complete pig on efficuency (about 83% as far as I can figure), but I'd still like to replace it with something new and more efficient. Boiler is for hot water radiators, not steam. Also the hot water heater is about 9 years old, still working for now.
So, I'm considering a high-efficiency boiler and have seen all the really efficient ones are condensing boilers (where they condense the combustion fumes/vapors to recapture extra heat). They are expensive, but will likely earn it back over time, or at least break even, and there is the added bonus of them being better for enviro (i'm no greenie, but we should all do our part) and also that they're now "smart" with much better computerized control over burn times, lengths, adjustment of flame, etc.
But, i've been reading they're a relatively new product, even worldwide, so they don't have the positive history that, say, a tankless water does in virtue of being used everywhere else in the world first. This is not to say they're prone to break down, just that they're uncertain. Also, many have a cast aluminum chamber, whereas some are stainless stell. There may be one or two cast iron still used in the now common venturi-type design. I've been reading that some suspect the iron or stainless stell will last better than aluminum, but no one ones. But they admit they're guessing and going on preference for pig iron. I'm looking at the Weil-Mclain Ultras, Peerless Pinnacle, Burnham Revolution (?) or if I can afford, a Buderus or Viessman. I'd also like to get an indirect fired hot water heater to further gain efficiency and savings.
So, anyone have any expierence in using or installing these things? Are they all they're cracked up to be? Am I better to just get the latest mostly-efficient cast iron typical/normal boiler and a tankless hot water heater and pocket the savings?
